opening the box
Everytime I would rotate in the X-axis the top of the box would rotate 90 degrees but when I rotate in the Y-axis everything sticks together like normal
  • spikeyxxx replied
    Hi ccryogenicfreeze22
    It sounds like you need to apply the rotation of the top. CTRL+A > Apply Rotation.
    Remember that the lid is made from a Cylinder, that was rotated 90° in Object Mode....
    So your situation looks something like this:
    As you can see, the orientation of the axes of the Origin of the lid is not the same as that of the 'World'.
    Also, in the N-Panel the Rotation is not 0° in all fields.
