2.8 Multicolor Wire Frame
Does anyone know if you can make wire frame multi-color? What I mean by that is if you have say three objects: body, coat, hat.....can you assign a different color to each object's wire frame view so you can see it all multi color?
Thanks
  • spikeyxxx replied
    ffxswan you can set the wireframe to Random Color:
  • spikeyxxx replied
    If you want control over the wireframe colors, you'll have to set the Viewport Display in the Object Properties Panel to a certain color and choose Object in the shading dropdown:
  • Chuck Shultz(fxswan) replied
    Thanks All..... appreciate it...
That lesson does not exist.
