Smoke particles not showing up in either Rendered Image or Animation.
At no point do the particle show up during rendering time. They are however checked to to be rendered.
  • Jonathan Lampel replied
    Hey sstoneocean , in your scene do you have the Smoke Particle object assigned as what the particle system should render in the particle properties Render panel?
  • stoneocean replied
    Nevermind I found it! It was the Smoke Emitter that was disable for render.
    Thanks for the help tho.
