knife tool on top iron band
When I use the knife tool on the top iron band in local view, the bottom iron band is also effected. When I make a dent on the top iron band the lower will have exactly the same dent as soon as I exit local view
  • Kent Trammell replied
    They must be sharing mesh data. You can confirm this by checking your object data settings and looking for a number of 2 or greater beside the mesh data name:
  • sheila5 replied
    O yeh I forgot you could use that to quit sharing the data. thanks kent
