Problem when making manifold after boolean
When I try to make my object manifold after I do a boolean, this happens:
The weird thing is, it only does this on a few of them, but not all of them.
  • Markus Berg(thebergh) replied
    Near the bottom of the error message it says: "No edges selected". Try selecting the geometry that you want to make manifold, and try the operation again.
  • Cookie Dough(cgcdough) replied
    I guess I should have added that part in, I tried that several times. After it does the operation, it deselects the geometry.
    Ok, so I played around a little bit and I was able to get the error as well. It seems to happen when the addon doesn't like the  threshold value. Try changing that to something else...
    The threshold for the boolean or the manifold?
    For the manifold. I got the same error message when I changed that too much.
    It's still not working.
    Really sorry to hear that. Playing around with it in 2.79 I don't get any error messages. I guess the addon is a little broken in 2.80. When I got the error message, I just pressed Esc and continued to play with the manifold threshold. Then again, I just used simple geometry to test... if that still doesn't work for you....guess I'm out of ideas...
    I probably could just copy paste to 2.79 if it works there. I'll try it tomorrow.
