Can't find stretching heat map overlay on Blender 2.8
posted to: UV Unwrapping
 Can't find that option
  • Andrea Weikert(elubie) replied
    The heat map overlay is a bit hidden in Blender 2.80. If you go to the UV editor and open the side-panel (with the N-Key) there is Display -> Overlays -> Stretching.
    Below this you can choose Angle or Area.
  • Alejandro Escobar(alej0) replied
    Where's overlays?
  • Markus Berg(thebergh) replied
    That would be in the View tab -> Display -> Overlays
    Still can't see it
    Found it, for some reason I had to change from the tab "4 UV Editing" to the first "Modelling", that also adds more options to the UV Editor, now my question changed to "Why's that? It doesn't make sense"
    My Blender doesn't have any numbers in the tabs. Which version of Blender 2.8 are you using?
    2.8.0 , downloaded from steam
    Hmm, I see. I'm just surprised that your Blender seem different, to the point where we weren't able to help you properly. So it says "2.80.75" in the bottom right corner of Blender?
  • spikeyxxx replied
    Like Markus  said, this is what the official version looks like:
    Maybe download it from Blender.org...
  • Jonathan Lampel replied
    It's probably just preferences carried over from 2.7 - I also organized my layouts like that! It would also explain why the headers are at the bottom.
    When opening up a 2.7 file, try un-checking Load UI in the file browser open options so that you get the 2.8 layout.
  • spikeyxxx replied
    Good point @jlampel, but that doesn't explain the numbers at the Workspaces.
    I'd guess it's an old Blender version combined with the Load Ui from 2.79...
    I have absolutely no idea as to why anyone would prefer to use Steam for Blender???
    thebergh spikeyxxx  I just checked and it says 2.80.75 . I downloaded Blender from Steam just because I always use It, I didn't think it would be any different from the regular Blender.
    @jlampel It worked! Also the numbers from the tabs dissapeared,  I'll take that into account when opening older files from now on.
    Thank you everyone for your help :)
    Great!
    In 2.7 the only way to organize layouts was to number them since they could only be in alphabetical / numerical order. If you want a real blast from the past (with lots of voice cracks probably), here's a video I made about that topic 6 years ago 😄
  • spikeyxxx replied
    @jlampel You are sooo wise!
    I tried opening a 2.79 file in 2.80 without loading the UI, but it probably wasn't old enough, so I didn't get the numbered workspaces;)
    There are some customization options where you can tell each workspace what kind of menus that it will allow........but with great customization power comes.............
  • jeremywalton replied
    This is where it is for 2.9
