How to add edge loop on cone ?
I cannot use Ctrl + R to add edge loop in cone, plz help
  • Sudeep Singh(hellosudeepsingh) replied
    thank you, didn't know we can bevel the vertex
  • spikeyxxx replied
    Hi hellosudeepsingh , no, a Cone consists of triangles, you cannot make an edge loop through CTRL-R.
    What you can do, is to go into front orthographic view (if the cone isn't rotated..) and use the Knife tool:
    Press K (knifecut)  C (constrain the cut to an axis)  Z (cut 'through the mesh') and make a straight horizontal cut.
    If you are using 2.80, you can also use the Bisect Tool:
    If that's not completely horizontal, you can select the 'cut' and press S Z 0.
    In both cases, you can use G G to slide the 'loop cut' up and down.
    thank you sir
  • spikeyxxx replied
    hellosudeepsingh , you're welcome, Jonathan Williamson's way is probably easier;)
    To bevel a vertex, select the vertex and press SHIFT CTRL B.
    You will however lose the point of the cone that way....
