UV test is not displaying properly.
posted to: Laying Out UVs
Hi Kent, so for the UV test image. You get the image shown at 25:50, when I try to do that I get the following.
What is happening?
Actually never mind about the first question, I just had to go to the materials tab and select the treasure_chest material.
How did you apply the same material to all the objects without going to each individual object and editing the material?
  • spikeyxxx replied
    Hello knightwolf
    Select all the objects you want to assign the material to. Make sure that the object that has the material is the active object (orange outline). Press CTRL-L > Make Links > Materials.
  • Kent Trammell replied
    Spikey is correct about "Make Links". There's also another way:
    • With all desired objects selected, select the object with the desired material last so it's the active object. Then go to the material properties and click the down arrow bellow the + and - buttons. From that menu you can choose "Copy Material to Selected".
  • knightwolf replied
    Thanks!
    Thanks!
