How to unwrap basic cone and torus shape?
posted to: UV Unwrapping
I want to apply wood or any image on this kind of shape. so how do I unwrap it without distortion?
  • Kent Trammell replied
    I would set the bottom edge circle as a seam along with one vertical edge:
  • Jay Padhya(jaypadhya) replied
    thank you for your response.
    I am not getting seamless texture with this method. How do I get that? I want to take this cone to substance painter, put base wood or any  patterned texture and  paint on top of it.
  • Jonathan Lampel replied
    There's almost never such a thing as a seamless texture with no distortion when unwrapping, but you can cover it up by painting across the seams. In Substance you can also try using tri-planer projection as your mapping, which will give a smooth projected result.
    Thank you..will look into it!!!
  • spikeyxxx replied
    In 2.80 al the primitives already have UVs.
    This is how the Cone is unwrapped (no seam on the 'top part'):
    thanks..good to know !!!
