is there away to...
Do a clay render with all the maps besides using a shading or image texture?  So the object will be in a white clay render but detail will be visible?  Also, can I get your email to send a plank file  BY USING PASTEALL.ORG?
 so you can see what I'm doing wrong?  I have the plank uv, I am using the node wrangler, I'm setting up a environment texture with a hdr image or  hdr exr file  but I still don't see any of my wood details.
Thank you for your time and any help or advice you can give me.
    If you use workbench as the render engine there are some nice quick shading things you can accomplish.
    but it doesn't make use of the shader nodes at all. just a working render engine to help you as you model or build scenes.
