How to rotate thoose planes as in video? When I hit R it's just rotate them algin to view
posted to: Blocking Out Panels
  • spikeyxxx replied
    R rotates along the view axis.
    R X rotates along the x-axis. (Similarly: R Y and R Z). (If you change the Orientation, the axes might change direction, therefore the rotational behaviour could be different;you can use this to your advantage!)
    R R rotates 'freely' (no axis constraint)
