2.8, sculpting hotkeys not working.
Is anybody experiencing the same problem as I am? Whenever I sculpt in Blender 2.8, some of the brush shortcut keys don't work. More specifically, the numbered ones.
I used to be able to use the keys 1-9 to select various brushes in 2.79, but I can no longer do that in 2.8. The only shortcuts that work are the lettered keys. Is this intentional or an oversight?
  • spikeyxxx replied
    Hi shisou, that is intentional. It's called a minimal keymap....
    You can, however change that.
    Go to Edit > Preferences > Keymap > 3D View > Sculpt > Sculpt(Global)  there you can find, change, even add shortcuts.
  • shisou replied
    spikeyxxx So I see. That's a minor inconvenience, but one easily solved. Thank you for your help.
