Bend a simple object. in my case a bridge.
Hey there :),I created a bridge in Blender (first picture). Now I wanna bend the bridge like on the second picture. I tried the same technic as in the tutorial with the shield (https://youtu.be/UfI7VLW1BJY?t=984). So I used the Lattice and put a simple deform on it. The result is weird to me.
Maybe you can help me out with this problem. Thanks
  • spikeyxxx replied
    Hi snowingname, did you put a Lattice Modifier on the bridge? With the Lattice selected? Because the bridge doesn't seem to be affected by the Lattice.
  • snowingname replied
    spikeyxxx Hey spikeyxxx, thank you for the quick response. For this example I did not combine. But there is a picture with the deformed mesh.
  • spikeyxxx replied
    ssnowingname Okay, so the bridge deforms, but only very little. I would say, that this is due to the fact that the bridge doesn't have enough geometry to deform.
  • Char Hunter(Char) replied
    ssnowingname  You could also try proportional editing.
    https://www.indiedb.com/groups/blenderheads/videos/8-proportional-editing-by-neal-hirsig
    As spikeyxxx  said you will need enough geometry to bend the parts.
    @charmn-one Thank you both. I try it :)
  • spikeyxxx replied
    ssnowingname Also, if using a Simple Deform Modifier, you might want to change the Origin of the bending to get the bridge to bend like in the reference:
    @charmn-one Thank you a lot the proportional editing thing + more geometry worked very well!
    ssnowingname Sweet!! Glad it helped. 👍😊
