Help With Uploading a Project to the Gallery
I have a project I just uploaded to my profile.  When it appears in the Gallery the top of it is cut off.  Is there any way to crop or re-center the image so that the top is seen in the Gallery?  On Behance, there is a tool that allows it to be cropped / centered before it's added to their gallery.  The top of my project is pretty central to the entire work and I would like it to show up in the gallery.
  • spikeyxxx replied
    Hi, zonkerzebra, you'll have to do that before uploading the image. you'll have to upload a square version for the Gallery image. You can use GIMP or PS or any kind of image manipuation Software for that or re-render the part you want to be seen in the Gallery with Border Render. 'Inside' you can then of course also upload the full version, just use the square one as the 'main' picture, that shows up in the Gallery.
  • zonkerzebra replied
    spikeyxxx Good suggestions.  Thank you!
  • spikeyxxx replied
    You're welcome. I've seen your image and it's quite good I think. I totally aggree that the head should be seen in the Gallery Image. I actually never thought about it, but your question helped me too. I will keep that in mind when I upload non-square Images to the Gallery next time, so thank you too for your question.
