Need help with Blender settings
Hi guys.
I did something (again :D).
Is there a setting I probably changed that does not alow render to update? Every time I am rendering I am getting a render from like week ago without any changes.
Please help.
Dragonice :)
  • John Sanderson(procyonlotor) replied
    do you have anything in the compositor or VSE?
  • Dragonice (dragonice69) replied
    pprocyonlotor I have stuff in compositor yes. What is VSE?
  • smurfmier1985 replied
    dragonice69 Video Sequence Editor, for editing videos and animations and such 🙂
    dragonice69 if anything is in the compositor or VSE, it can override the render output in the image editor.  If it looks like your image is rendering normally and then it  changes just as the render finishes, this is probably the culprit.  You can disable them under "Post Processing" in the render panel. If it's rendering the old image from the get go, then something else is going on.  I would probably need to look at the .blend to venture any further guesses.
