Shapekey mirror and Texture Atlas
I have a mesh that is perfectly symmetrical that I am trying to mirror shape keys on, but it keeps coming up with an error.  For some of the keys, it will target some of the correct, and for some it won't return any.  I can't come up with any reason this should happen, so I am looking for a solution.  The only thing I can think is that I merged it with other objects at one point using texture atlas, but then separated it again.  In the vertex data panel it does still show that it remembers that.  Does anyone know if that affects shape key mirrors?
  • Jonathan Lampel replied
    Hmm, this is a pretty specific problem that I haven't run into before. Texture atlas may have messed with it if you edited the object at all while manual unwrap was active. That sometimes causes other issues for me, so it could be the case here as well.
  • John Sanderson(procyonlotor) replied
    @jlampel Thanks.  I ended up appending to a new blend and that seemed to sort things out. Not sure what went wrong, but the solution was easy enough once I found it.
