• smurfmier1985 replied
    Good to see you back Wilco, glad you're joining us again! 😄
  • Wilco Wilbrink(carrotnl) replied
    Homework - Week 1 - Part 1:
    @theluthier:
    I made this exercise some time ago. I added stickers to some decals to it. This is the end result:
    -edit- And here's the blendfile (since I forgot): ToyTruck (with packed textures).blend
    ccarrotnl Wow, that looks awesome Wilco! 😃 How do you add those stickers on top?
  • Grady Pruitt(gradyp) replied
    ccarrotnl Wow! love the additional details!
    ssmurfmier1985
    Hey, thanx!
    (images will follow in a few moments)
    1. To add stickers I do the following: First I load the picture in the UV/Image Editor:
    2. Then I select the faces that I want to use for the sticker:
    3. I press to UV-unwrap the selected faces. I use the option Project from View (So the view must be aligned correctly):
    4. Then I name the new UV-map in the Data tab from the Properties Window:
    5. I setup the following node setup (look at the bottom (yellow) framed nodes). The first node chooses the UV-map. Don't forget to choose the correct image from the dropdown menu in the Image-Texture node:
    6. I align the unwrapped faces in the UV/Image Editor, while keeping an eye at the 3D View:
    I hope this explained it a bit. 😃
    gradyp Thank you!
    ccarrotnl Great explanation Wilco, Thanks! Gonna try it out on my own truck to practice it 😊 Looks so cool 😬
  • Morten Fjellheim(arev) replied
    Pretty original with textures and all.
  • silentheart00 replied
    Nice.  Great details.
  • Stephan (steph) replied
    Oh, the truck looks awesome and the stickers really add to it! Thank you so much for providing the additional explanation! Very helpful!
  • Pavel Mazanik(nekronavt) replied
    Huh, badass truck ;)
  • Aaron Rudderham(thecabbagedetective) replied
    ccarrotnl Absolutely lovely take on this exercise, and appreciate you sharing the tips to everyone! Good luck for the rest of the class.
  • Kent Trammell replied
    ccarrotnl Love the decal additions! What a nice touch. Really take the exercise up a notch. And kudos for sharing the tips 🙇🏻‍♂️
    @theluthier thecabbagedetective
    Thank you! Yeah those stickers give it an extra touch :)
    Homework  - Week 1 - Part 2:
    @theluthier:
    Here's the bedroom exercise. Here I also took a previously made exercise, and then I tried to lift it up a nudge.
    For both renders I used the compositor to get more contrast and to give it a vignette. Here it is:
    For who wants to see the blend files (beware: there huge):
    Bedroom - Daytime (hdr packed) .blend
    Bedroom - Nighttime (hdr packed).blend
    I'll put the blend file of the truck in the homework - week 1 - part 1-post, since I forgot to do that.
    ccarrotnl you're fast this week Wilco! Daylight, love the cloudy sky in the window 😊 the light on the pillows is a bit too bright for my taste, but otherwise nicely lit. The night version is very good!! Well lit, stars in the sky, nice mood to the light. Love it! 😄
    ssmurfmier1985 I just did an update of the nighttime render a few minutes ago. Maybe you just misted it? Not sure...
    I gave it just a bit more contrast, and made the bed lamps a bit brighter.
    ssmurfmier1985 Btw. I started out with previously made scenes, so I'm not really that fast. Just updated the old files a bit. 😊
    ccarrotnl I did see the vignette one and I love the night version as mentioned before so great job on that 😬
    Ah that would speed up things quite a bit 😆
