Can't post video in community?
Today I am trying to post a Vimeo video. It fails.
  • If I select "URL" and insert the URL, I get a message "Oops, the embed code is not valid."
  • If I select "Embed" and insert the embed HTML, I get the same message.
Thanks
The actual URL is
https://vimeo.com/279579974/7a123892f2
if that helps
  • Heather Peterson(hdpeterson) replied
    Have you got the sharing functionality turned on for your video? I can't find any sharing button or link that would allow the generation of an embed code or even a simple autogenerated link (aside from the browser address bar, of course). When I try to use the link from another video on Vimeo to embed here, it works fine. So, although I could be wrong -- I don't use Vimeo very much, I would check your sharing settings just to start.
    Example embedded video:
