[Question] tank chains
Hello,
 I am trying to animate the chains of a tank. I have made a simple chain part and applied a bevel modifier, then an array, a curve modifier and assigned them to a nurb-circle which I have modified to fit my tank. Both the circle and part (As far as I know) has been created at the origin. I also tried to place the origin at the center of the volume and at the center of the surface for both the chain part and the nurb-circle.
Everything went as I would have expected it. So I proceeded with my experiment.
I then wanted to animate (and later rig all relevant part to facilitate the animation of my tank),
so I applied a < follow path > constraint to the chain part to automatically animate it. There is an undesired effect.
Please take a look at this effect in the file I have attached.
I really would like any feedback.
Thank you in advance.
  • Char Hunter(Char) replied
    Macario,
    I'm not much at rigging and animation,  But I see something odd on your timeline at 5 seconds in the video.  Looks like jagged lines, then they straighten out.   Could you have keyed something offset movements there?
    Char
  • killer-wolf replied
    assuming you mean "track" and not "chains", if you check on youtube there used to be a good tutorial by, iirc, Chris Kuhn, on how to rig/animate this.
  • Thibaut Bourbon(tbrbn) replied
    mac999 I think kkiller-wolf is referring to this course:
    https://www.cgcookie.com/course/rigging-tank-treads
    Maybe you are actually already following it and struggling with a specific part of it ?
    tbrbn
    that's the one, i thought it was a youtube thing.  anything by Chris is top notch.
    cheers
  • Macario Lopez(mac999) replied
    Thank you to everybody.
    I will take a look at it:)
