The Porshce tutorial series.
Do someone know if the referance images used in the old Porsche tutorial series can be downloaded somewhere? Or is it posible to obtain them through the sourcefiles and use in a new blend file?
  • Jonathan Lampel replied
    Hey aarev , I put all the references I could find into the source files. To get them out, you can go to File/External Data/Unpack into Files.
  • Morten Fjellheim(arev) replied
    @jlampel You misunderstand. I know they can be found in the sourcefiles, but because i dont like the layout i want to export them into a new blend file. So the question is if its posible to extract them from the sourcefiles, into a new blend file?
    aarev Sure thing, you can unpack into files like I mentioned above and then you could import those images into the new .blend file.
    Also, if you don't like the layout, you can start Blender fresh, go to File/Open and navigate to the file, and then before selecting it you can un-check 'Load UI' so that the file's layout won't change your defaults.
    @jlampel Figured it oput, thanks:)
