Blender - Cycles - How can one create a normal map?
As follow-up on my question about transparant plastic foil pattern I was wondering:
How can one create a normal map:
- Can this be done inside Blender?
- Can this be done by manipulating a(ny) texture into a normal map?
- Does one need external programs to do so?
Thanks for all hints, tips and tricks.
  • Jonathan Lampel replied
    Sure thing, for the purpose of what you're talking about, you can convert any texture into a normal map by using the bump map node:
    You can see what's going on by the colors of the connectors: the bump node takes a greyscale input (if you put in RGB it'll be automatically converted) and outputs a normal value.
  • Matt Curtis(jbird09) replied
    Also CrazyBump is free and very useful for getting a decent normal or height map from an image.
  • Ronald Vermeij(indigowarrior9) replied
    @jlampel : Thank You Jonathan, for adding a Cycles node-editor picture to your answer
    Q:Do you also know how his can be done with the Blender Internal render engine?
    jbird09 Thanks Matt. [x] CrazyBump checked and bookmarked.
    This is something I've used to generate quick normal maps outside of the typical programs used: http://cpetry.github.io/NormalMap-Online/  It also outputs different maps like height, AO, and specular.
