need tips on hardsurface
im trying to create the pink part. but for the life of me i couldnt get the curve part.. any tips? ;'(
  • Panus Boonyok(zenogias) replied
    I am not quite certainly sure what do you mean "I can not get the curve part".
    If I were you I would just add some more loop cut and move them one by one by scaling on X axis to make some curve.
    If you're trying to curve the mesh you'll need to add more loop cuts then you can move them into position to form the curvature.
  • n647 replied
    really would recomend to use the greae pencil to daw the main curves on the reference drawing, that will give you a much better idea of the shape you have to follow
