Help Exercices Bake hard surface
Someone have made this exercices ?
https://cgcookie.com/exercise/bake-a-hard-surface-normal-map
I can't create a perfect bake on this exercice.
On High poly :
- I've add a Bevel modifier and used bevel weight. + Sharp all edge I've bevelled.
On Low poly : all edge bevel in High poly are Sharp edge too.
I
Low poly
High Poly
  • Jonathan Lampel replied
    Hey Martin, my first guess for black lines along edges is that they should be marked as seams. If you're not already, I would suggest using a cage as well since some sort of overlap issue would be my next guess.
