further issues with UV MAP
Beginning to wonder if maybe the issue lies in my model...so, here is what is happening with my normal map and ambient occlusion map.
this is my UV mapping
and a screenshot of how my setup looks....I'm just stumped...
(note: i'ce tried tweaking the bake settings as far as ray distance and margins....
  • Dolores 74 (dolores74) replied
    Check out the Guru his tutorial somewere @ 8:23. Maybe that is the issue.
    A help to find the ray distance are the normals. Activate the normals to see if no normal is hitting an opposite face and use that normal length as the value for the ray distance in the baking tab.
    Your UV looks a lot simpler now.
  • unicornsammich1 replied
    That did help a lot. I think its about as good as it's going to get at this point lol. I appreciate the help seriously! I may have bit off more than I can chew with this being my first character model. Thank you though.
  • Chetan Ranjan(ranjancnr) replied
    unicornsammich1 Your UVs look a lot simpler now. Great job.
    Since Dolores has already solved your problem, I just want to add that maybe you can look into using xNormals. It is a software specially designed for baking.
    thanks! I will look into that for sure :)
