computer crash with rendering model need help
like the titel say my computer start to crash (sometimes i am able to render 1 time but when i do this a second time without restarting my computer it crash ) and sometimes this happens also the first time.
this is the type of computer i have
geforce GT 640
other information on computer
if you can help me but need my file to check out if there is another problem let me know then i send over the file in a message
  • Ben Burgess(benburgess) replied
    Throw it out a window. That'll show the computer whos boss.
  • Jonathan Lampel replied
    It definitely depends on the file, try uploading it to PasteAll and adding a link to it here.
  • 29632963 replied
    lol i dont throw out my computer :p then i lose everthing xD
    i uploaded the file
    http://pasteall.org/blend/index.php?id=48378
    hope someone can find out the cause of it :(
    It doesn't crash on my system, but it does take forever to build the BVH for all those hair objects. I think you just have too many hair particles.
  • 29632963 replied
    hmm ya but with lesser hair you see the scalp of the head :s is there a way to somehow fix that then ? like if i lower it to 500 or 300 that the end result still will look good for when i want to animate it ?
    so you also rendered it then i suppose ? does it also takes 2 hours or not so long ?
    the crash is then because of too many hair particles
    Try using something like 10 main hair particles and then use lots of children particles to fill in the space. Since children are instanced, it should save quite a bit of time.
  • 29632963 replied
    thanx indeed this helped a lot it renders faster and i did not get any crashes anymore :D thanx so much
  • 29632963 replied
    question is there a way to to fix this ? as you see now in side view it looks pretty much ok (front hair bangs ) but in front view its like she does not has a lot of hair in the front (front bangs) now i was thinking about changing the amount of hair particles but if i do that this happens for all hairlocks :s this is the picture to see the problem
  • 29632963 replied
    seems i got it slightly better (but now the hairs strokes are pointed )
    here you see what i mean. also the first lock number one cause some hair to stand out at side :s how can i get this better? hope these 2 problems can get fixed
