Propeller Rotating Off Center
The propeller's center doesn't stay in place as it rotates (visible if you watch the Z-axis at 02:11). Is this just something else going on with the script?
     I believe the pivot point was slightly off center so it may have looked like it was rotating a bit differently. The script is only rotating the object along the Z axis.
