Face creation - not linking to closest vertex
Hi when I do the F2 - Face creation in the same perspective and cursor position as show it creates a face with the point on the opposite end of the lid and not the points above, did I miss a setting somewhere?
  • dmalyavin replied
    Well didnt get any answer from here, but basically its creates a face with the closet edge in 2d space, so the cursor needs to be close to the point above
  • Kent Trammell replied
    Sorry for the late reply. You're right that with F2 it sources it face-filling direction from where you mouse cursor is located.
    Thanks for following up your question with the answer you discovered.
