when I apply bevel modifier
applied surface broken, how can i fix it?
  • Jonathan Lampel replied
    Hi! It looks like some edges are being beveled that should not be. Make sure the Limit Method is set to Weight and head into edit mode and adjust the weights of those edges. Any edges that are not corners should not have any weight, which shows up as a blue line.
