Animation is not always smooth, and some peculiarities
I understand this is probably just a basic example to demonstrate key concepts, but how would one go about solving these issues:
  • At 10:26, the character jumps briefly into the standing position. I'm guessing this is because the beginning of the turning animation clip is the character standing? If I hold down W + A/D and basically just keep turning forever, every time the 7-second turning animation clip finishes, the character goes back into a standing position briefly before continuing the loop.
  • If I keep turning forever, a weird thing also happens where the character starts sinking into the ground. Is the character possibly slightly beneath the ground at the 7-second mark where we trimmed the length down to?
  • When going from idle to left/right, the animation looks a little odd if a specific leg is forward; it looks like the legs freeze in place while the whole character tips to the side to begin the turn.
  • When trying to go quickly from left to right directly or vice versa, this results in a jerky animation.
    A lot of the smoothing issues come down to the animation clips themselves and how they are meant to be used. The mocap animations are "raw" so they were included without any proper editing to ensure they'd smoothly work together. You can try out animations from Mixamo: https://www.mixamo.com/#/?page=1&type=Motion%2CMotionPack, I've had good results with those. Sometimes they can be a bit quirky in Unity, but for the most part the movement animations work well together without any issues.
