How to I bring back edit mode shape into object mode?
When I go to Object mode on my arm_lat it mimics the shape of my Empty(cube) when I put it to edit mode it finally goes back to the shape it should be!
  • Kent Trammell replied
    Did you scale and position your lattice in object mode or in edit mode? The correct method is scaling / positioning the lattice to encapsulate your arm model in object mode, then deform the lattice in edit mode. Doing it the other way won't work as expected.
