Window reflection doesn't work (again)
The material has been assigned as far as I can tell; I am in Look Dev mode, here are the settings:
  • Grant Wilk(grantwilk) replied
    Everything should be working properly still. I can see that the material is still applied to the face and that it is set up correctly. This is likely just some weird rendering quirk. Just proceed as usual and it'll come out fine in the end :)
