When I switch from edit mode to object mode, the triangles disappear
Here's my screen shot while still in edit mode:
  • Grant Wilk(grantwilk) replied
    Instead of switching into edit mode, try switching into wireframe view mode by pressing Z and clicking the "Wireframe" option like I mention at 2:58.
    It should yield a result like this:
  • vndep replied
    I was already in wireframe view mode
    Would you mind showing me what your screen looks like when you switch into Object mode, then Wireframe view mode?
    Regardless, the triangles are there, so you should be okay to move on with the course. But I get that it would be nice to have some additional confirmation that everything is working properly :)
  • vndep replied
    Ah, I see! You're having the same issue as another user. Check out the solution found here: https://cgcookie.com/questions/8343-i-don-t-have-lines-displayed-after-subdivision-surface
