Incorrect values are saved when I insert keyframes
posted to: Follow Through
The wrong value is recorded whenever I insert a keyframe and I have to manually copy and paste the correct value from the 3D viewport to the graph editor.
For example, I right click on the X Location of the CURVEMID object in the properties pane and then I click "Insert Single Keyframe."  The value of the X Location according to the properties pane in the 3D viewport is -9.04136.  A keyframe is successfully added in the graph editor.  However, the value of the keyframe in the graph editor is -15.2674 instead of the correct value of -9.04136.
 Any ideas on why this is happening?  Thanks!
  • Jonathan Lampel replied
    Hey, that's an interesting situation! Can I take a look at the file?
    P.S. I won't get a notification unless you @ my username since I'm not the instructor of this course.
