human import not showing up
posted to: Blocking the Door
I have imported the human character into my scene but under collections it is grayed out. and the view option(viability is on) what do i need to do to see the model?I just spent an hour trying to figure out why it was doing this. check out (25:10) to know how to un -hide. Also 2.8 hides the option for display in view port under this icon(not sure if this was new to 2.8 or it was like that in 2.7 as well)
  • Jonathan Lampel replied
    Hey, thanks for following up with the solution! When I recorded the course the monitor icon was the default instead of the eye.
    Since you won't be the last one with this issue, I've updated the source files to use the new defaults so that it won't get confusing.
