Another way to sculpt?
posted to: Body Blockout I
Is there another way/technique to sculpt? This one is so random and messy. I try to drag a mesh to match the concept with the drag brush from front view and when i turn arount in perspective i see that i drag only half of the mesh...and after smoothing i need to drag mesh back, bacause smooth make the mesh smaller again...Its infinite
  • Kent Trammell replied
    There's a settings in the brush panel called "Front Faces Only". If you have that enabled then your brush will only affect the half of your mesh that faces you directly. As in the backside will be untouched.
    Digital Sculpting in Blender can take some getting used to. Keep practicing and follow through this whole course and you will be able to sculpt more naturally!
