Slash to hide but keep ref image
Hi,
When I hit slash to hide the ref image is also hidden. How is it possible to keep the ref image showing (2.8)
thank you
  • Jonathan Lampel replied
    Hmm, good question! That is unfortunate. I guess you now need to also select the images when going into local view.
  • imparare replied
    Ok that works but in your movie I am not sure that you do this. thanks anyway
    Indeed - I was working in 2.79, which behaves differently.
  • imparare replied
    It certainly does. I found it interesting that you use extrude (vert, edge) instead of the polybuild tool which I have used and seen others using. Its great to have a different approach - thank you
