where to find an updated tutorial?
I'm using 2.8 and a lot of shortcuts do not work (F6 for example, right click for moving origin, I have no panel to add objects I just press shift A), where can I find an updated tutorial?
  • lvl1wizard replied
    The only differences in 2.8 that I saw (as of this date) were the ones you mentioned:
    * Shift-RMB moves the cursor
    * Use Shift-A to add objects, or pick from the viewport Add menu
    * You don't have to hit F6; they pulled it out into a little fold-out dialog in the lower left of viewport
  • zeriel replied
    Just look up at the key bindings in the options to know where is what. I even changed some keys around to work as Maya and what you learn here is always the same even if the shortcuts are in different places. I could even do this in Maya and all that changes are the names of the tools because all traditional 3D modeling packages work basically the same.
