Blender 2.8 Keeps Crashing During Bake
posted to: Baking the Normals
Hello, I'm using the latest version of Blender 2.8 as of 3/15/2019 and I can't get past the second layer of baking (by that I mean the grouped items in "door_low_02"). Every time I try to get it to bake the program crashes deleting my normal map so I have to start all over again. Is there any alternative or any configuration to the render settings to get this to work? Or should I just keep trying until I manage to push through?
Thanks for any answer!
  • collini jou(collini) replied
    I also encountered the same problem, but for the time being I found a solution: Normal bake in default window, the probability of success is high, in shading window, blender often crashes, you can try.
  • Jonathan Lampel replied
    In addition to what Collini mentioned, I'd recommend reporting a bug any time Blender crashes! That'll make sure the problem won't make its way into the final release. https://developer.blender.org/
