Hi! . Is there an easy way to rig the cuff (border) of a sleeve so that when you rotate the wrist the sleeve stays still (The cuff should be deformed adapting the form of the wrist, just like the sleeve of a suit).Thanks
Hola! Hay alguna manera sencilla de hacer el rigging del puño de una manga de manera que cuando la muñeca rote la manga permanezca quieta. El puño debería deformarse según la muñeca gira igual que la manga de un traje. Gracias.
ddanielue In that situation I would probably separate the hand geometry from the rest of the body. Then you could have a control that rotates the hand independently from the sleeve geometry, yet they could still interact intuitively via IK .
