How to set stroke pattern used in tutorial?
How do you make the draw pencil change pressure begin/mid/end of stroke?
Mine stays solid and my googled haven't yet yielded anything.
  • sushemsu replied
    correction width of stroke not fade
  • Wayne Dixon replied
    Make sure you are using a brush that has pressure sensitivity enabled for the stroke width.  It's the little icon next to the size.
    I would post an image but I'm on holiday and don't have access to Blender right now.
    It's the blue button here sushemsu
  • victorchen2045 replied
    My blender 2.82 doesn't have the draw pencil type you were using in the video. And also I have  the pressure sensitivity enabled but it's still drawing straight line.
  • spikeyxxx replied
    vvictorchen2045 Draw Pencil in 2.80
    is called Pencil in 2.82:
    and if you have pressure sensitivity enabled on the Radius, (highlighted blue), that should work, unless maybe something is wrong with your tablet (are your drivers up to date? Does it have pressure sensitivity? Even worse. are you using a mouse?)
    Thanks for your quick reply! I have fixed it by installing the driver from Wacom website(I'm using Wacom CTL 471 ). I thought I could just use the driver that was automatically installed by the Windows system. :)
    amazing what up to date drivers do most of the time!!
