Do you know about the Shift + R command when aligning UV's?
I noticed when you were aligning UV's, you added Auto Aligning to your Quick Favorites menu. I was just curious if you knew about the "Repeat Last Command" hotkey which is Shift + R. This would allow you to remove the steps of adding Auto Align to your Quick Favorites menu and it would also cut out pressing Q every time you wanted to use Auto Align. You would just need to use Auto Align once and then hit Shift+R every time after that.
Not trying to force you to do it this way or anything, I just wanted to let you know it case you didn't already!
Cheers!
  • Jonathan Lampel replied
    Nice shortcut, I think that will work nicely! I'll give that a shot next time, thanks :)
