I like Diamonds <3
posted to: All Quad Junctions
https://imgur.com/hOZcvQi
,Corners: https://imgur.com/huoIhkT
And Flowers: https://imgur.com/veumUTj
Also Check this out: https://topologyguides.com/
Protip: Click on the camera (on the right from your snapping tools) to render you viewport. This allows you so save (save image) and present what you see without any hassle (like render using the windows cutting tool to get a picture.
Just getting excited with some interesting features :D. If you like accurate modelling then read on!
- Spin (Alt+R) with dupli enabled (-> Its like a screw modifier in edit mode)
- Set edge Lenght (Tools -> MeshEditTools -> Edge -> Set edge Lenght (not sure if its an addon)
- Angle Off Edge -> (edit mode) W -> Edge Tools -> Angle Off Edge
__________This allows you to create edges out of excisting ones, while manually setting the angle and edge lenght of the -> = shorter way of: (Vertex extrude -> Edge select and "Set edge Lenght" (counterclockwise) -> Cursor to vertex (.) -> rotate the new edge with the Cursor as pivotpoint.
- Symmetrise
- Ruler/Protractor; (T) -> Grease Pencil -> Grease Pencil -> Tools: Ruler/Protractor.
__________This allows you to measure exact lenghts of you edges (it snaps with ctrl). Plus allows you to measure exactly any angles, by click and pull the line after you create it.
- Knife = OP just like J.
Reply
  • Jonathan Lampel replied
    Very cool, thanks for sharing!
