in the "materials 2" lesson, missing a feature
posted to: Materials
not quite sure exactly what's happening, but when i open up compositing, i;m not met with a "diffuse bdsf" menu, and can not add any sort of element from a "shader" dropdown. what's going on? am i missing something?
  • Jeff Lange(jefe317) replied
    You're probably not in Object view. Make sure the orange box icon is selected, not the globe or pen icon.
  • gamedev_chuck replied
    I just came across this too. It's a pretty simple (but important) setting. You need to change from the default Blender Internal Render to the Cycles Render. On the top middle of your screen, click the drop down that says 'Blender Render' and then select 'Cycles Render'. You should now get the Diffuse BSDF and Material Output nodes in the composite editor when you create the new material.
