Problem with grab brush.
Hey, sometimes I have some Problems with my grab brush. You pulled the part of the shirt easily down to the arms in my case there causing problems (see picture). This also happened a lot around the beard.
  • snowingname replied
    Ok I found the problem on my own. I checked "Front Faces Only" this was causing the problems. Maybe it helps somebody.
  • Kent Trammell replied
    I'm sure it will help someone. Thanks for posting the solution you found!
