Texture viewport shading doesn't look correct. How to fix?
I'm having a problem - when I switch to texture viewport shading, this is what I see.  When I switch to rendered viewport shading, the texture is clearly applied:
But I can't figure out why the texture viewport shading looks so different.
  • Kent Trammell replied
    jjohnnicely Hmm I wonder what's happening there. If you provide a download link, I'll be happy to take a look at your file to see what's going on.
  • velarc replied
    I had the exact same issue. I solved this by firstly making sure all images and projects were saved and then re-opening the blender file. Hope it works.
