Pole Target issues
posted to: Rigging the Wing II
When I added the pole target the elbow rotates and does not point to the target in an intuitive way. Image one shows the bend, then I go into edit mode and it looks fine, which is the second image below. Any help is appreciated
Thanks
Nick.
  • Kent Trammell replied
    Can you proved me a download link to your .blend file via Dropbox or Google Drive (or equivalent) so I can take a closer look?
  • Nick BURGESS(nburgessdla) replied
    https://drive.google.com/file/d/1sfunN9fabSvKuC2utGwzcB9IooarQC3L/view?usp=sharing
    I found the issue for this problem but also found a different one. I fixed this by rotating the joints, but when I did the defJoints are not pointing at the target pole any more. I followed the tutorial through the rest of the rigging, because you had the same problem but your solutions didn't help. thank you for the response and love your work.
