Can someone tell me why the stomp char. disappears.
posted to: Stomp Walk Cycle
Can someone tell how the stomp char. has dissapered from the scene after I have uploaded the file youtube.
  • Wayne Dixon replied
    You'll need to provide more information, Samuel.
    Maybe the character is on a layer that is not visible.
    Maybe you have scaled it to 0,0,0
    Maybe you have accidentally deleted it, or keyed it out of the camera view, or it was abducted by aliens???
  • Samuel Bouillon(sammsamm) replied
    Wow, thanks replying soon. I can't understand, I have 4 or 5 files getting ready for test, an sending to you tube, boof, I send to you tube, upload. And now when I open one of the stomp files I have prepping for test, the stomp char. is not in the file. I  had three scenes, all with different titles. There is a dot to indicate there being an object in layer one, and the stomp rig sows up in the outliner. I am not sure what or how to get stomp rig to show.
    Wow, thanks replying soon. I can't understand, I have 4 or 5 files getting ready for test, an sending to you tube, boof, I send to you tube, upload. And now when I open one of the stomp files I have prepping for test, the stomp char. is not in the file. I  had three scenes, all with different titles. There is a dot to indicate there being an object in layer one, and the stomp rig sows up in the outliner. I am not sure what or how to get stomp rig to show. abducted dang ye.
    if you have moved files around, which is sounds like you may have done, then make sure you didn't break the links to the library.
    If that is the case, the easiest thing to do is to put the linked character in the correct spot and reopen your animation file. BUT MAKE SURE YOU DON'T SAVE THE FAULTY ANIMATION FILE BEFORE YOU MOVED THE LIBRARY FILE BACK.
    That bit is in capitals because it is important.  After you fixed the broken location, feel free to save your file then but if you save a broken file, it stays broken.
