Problem with dayligth
I am trying to add a spot ligth outside the window to blow a little bit the image and add the yellow reflection that appears on the photo, the problem is that my ligth is not affecting the image at all. What I am doing wrong? An also what other way I could make that reflection?.
  • Kent Trammell replied
    A few questions:
    1. What render engine do you have enabled?
    2. What's the strength of your spot light?
    3. Why not use a Sun lamp?
