Weird texturing of room
Hey, I'm getting the following result: https://imgur.com/a/okA7ajH
What am I doing wrong? :\
  • Eldad Bercovici(dutzi) replied
    Ok, I somehow got it to work, but I still don't understand what I did wrong in the previous attempt. Can you please explain?
  • Kent Trammell replied
    It seems like you've got faces on top of faces in the UVs or in the mesh itself. Is that the same scene we provided for download in the source files?
  • izuul replied
    Just in case you are still wondering, I found out what you did wrong(I did it myself...)  You didn't assign an image texture node to all of the materials.  Once you do that, you get the correct appearance.  I hope that helps!
