Grass is using my plain material
posted to: Shading Mesh Grass
It is using the Material and texture from the ground and not it's own. When I go into the particle system settings, it won't let me change the material (it is greyed out).
  • Jonathan Lampel replied
    Hey Albert, if you're using Object for the emission, then you can change the material by changing what's assigned to the source object itself instead of changing it from the particle settings.
  • Albert Brewer(t1nyd4nc3r) replied
    It is currently set to "Group". When I change it to object, all the grass disappears.
    Oh that's right, we are using Group here, but either way you can change the grass material by changing the materials of the objects in that group.
